CalsXS2
XS650 Guru
- Messages
- 1,006
- Reaction score
- 52
- Points
- 48
Well I'm trying to make a new upper motor mount so I can run a Detroit Bros deep tunnel Instigator tank. So I need to do a little trimming on the inside of the tab's so I can make a mount like the one pictured. It goes in the center of the frame and that what I need to run this tank.
I needed to take off the pcv box so I could see how much I could grind. Good thing I did too. There's no room to take anything off of the outer edge's. As I was taking out the bolt's from the pcv box 3 of them broke off in the motor. I'm going to see if I can weld a nut on the stud that is sticking out. If that won't weld, then I'll try JB Weld. If that won't work,,,here's finally the point of the thread. Since I have one good bolt hole, could I just use some kind of sealer and hope for the best. That's just a vent,,right? I really don't want to pull the motor to get these bolt's out. Any idea's. Thanks.
