oil pressure 650 engine?
Yep, oil pressure is generally a non-issue on this motor design and will vary depending on where it's measured and at what temperature - single digits to a fraction of a psi. What's important is volume - in practice if you're getting good flow at the rocker shafts, you're good to go.
