very interesting thread and very relevant with the current temperatures.
I'm kind of surprised that nobody yet ,(other than Bob
),has really mentioned the part the exhaust valves play in the overall temperature of the engine.
Someone needs to do some temperature testing with all the various yamaha recommended valve settings throughout the XS650 model range
There is a really interesting article written by a Brit Engineer who specializes in building XS650 /850/rephased engines for racing. Howard of Smedspeed.
Here is the article which is a thoroughly interesting read with a cup of coffee.
http://www.smedspeed.co.uk/tech.html
Howard did some intensive testing of the various valve train components,valve lift against cam rotation etc of the various models together with a study of how long the inlet and exhaust Exhaust valves were actually held slightly off the valve seats each cam rotation. It turns out to be a huge!
The slow ramp of the later cams give a Inlet cam event total of a staggering 395 degrees ! ( 93+180+122), with absolutely no benefit whatsoever in terms of increased inlet flow but a significant reduction in heat transference from valves to seats to head fins.
Howards conclusion was summed up thus.
The late XS650 cams set at .002" intake tappet setting is ridiculous. I can’t think of another OHC engine with valves this size that has such small clearances, the camshaft has a run-out of over 0.002 in many cases and setting the tappets to this small clearance will allow the valve to stay open perpetually. It is an effort by Yamaha to reduce engine noise, but this is not the way to do it.
I set all the tappet clearance at the early settings of 0.006 and 0.012. It allows in more oil, and allows for a generous growth in the metal parts, remember….. A loose tappet is a happy tappet.'
