Stever_G
Or remove it from the equation, if it is the problem.
Here it goes, the bought bike with turn signals that would remain on. thought I could simply replace flasher relay no problem. Blinker High /lo switch in rough shape I'll replace that as well. some po janky connections behind the headlight so I thought oem harness should be safe bet and help work out confusion. replaced harness and everything went well, only thing questionable about install was connection for the tachometer high beam indicator and illumination light. Now headlight doesn't work, tail light works but will not brighten when brake switch triggered, Blinkers do nothing. It did run when I started this project now I'm afraid to put the tank back on to see. And i feel like I'm wasting other board members time and patience by posting a question thread when I should be reading the prior posts.
