txpowdercoater
- Messages
- 206
- Reaction score
- 2
- Points
- 16
The rundown.
81 xs 650, wiring totally removed and redone with only headlight (wired through relay and neutral switch) and tailight. No E start and a UB1250 5amp hr battery.
Wiring is a breeze to me and everything is connected as should be.
the problem is:
I think its overcharging at high rpm's and it toasts the battery, end result, me pushing it home twice.
The first time it happened, I did an 85 mph (gears 18/30 so rpm's werent screaming like when it was stock at 70mph) blast down the freeway for 5 minutes each direction, then got 1.5 miles form the house and it died at a light. I had zero power so I know its not gonna start so I push it home, after I recovered from the heat induced heart atttack and the 3rd degree burns from my balls bursting into flames, I check it out and find the battery is toast, no resistance at all between the contacts and all is wired correctly as I knew, and if I stuck a new battery in it worked perfectly at around town riding and such, all day on and off no problems. With a voltmeter, trying to check the battery voltage while revving in neutral, it spiked to 15.3 but at lower rpms was in the 13 range.
soooo, I hop on the freeway again and do another run, buzzing about 5 minutes again each way, this time made it 4 blocks from the house and died at a light and also dead as a doornail. checking again, battery is toast.
need to change regulator or get a better brand battery?
what if I wired another relay to work off of the neutral switch to disconnect the battery when its in gear and charges it when in neutral? the battery is plenty big enough to give lots and lots of kick starts w/o any charging at all, so does that idea sound ok or does the charging system have to have the battery as a load? Thinking the headlight at 40+ watts and engine running should be enough of a load, yes?
the problem is:
