One up or one down, sprocket questions !
Paleomechanic
Martindale quebec
So, having passed the very tough Quebec Mechanical Safety inspection , I’ve put on 100km of “legal” breaking in lol ( it’s been lower speed dirt roads until yesterday!)
So, I’ve owned these enough to know they have a certain buzzy power band at spots
What I’d like to do is look at dropping the rpm just a little right around 110 km hr ( about 65 mph )
So, one tooth up on the front or one less on the rear ?
Thoughts??
Thanks all!
Happy Saturday!
Nick
I've run two down on the rear (32) with a 16" tire and would have broken somebody's hand if they tried to change it, I now run stock 17/34 on an 18" rear tire and I'll break anybody's hand that would try to change it.
....I'll add that thinking back I had to remove a link in the chain for the 32.....
18 teeth on the front sprocket starts putting the stator harness and clutch pushrod into the possible danger zone of getting chain chewed, I got tired of thinking of that possibility when riding.
I've also gotten tired of second guessing Japanese engineers.
What Greg said. You can go up to 18 on the front, but the design doesn't lend itself well to it.... clutch pushrod's pretty close.
I run an 17/31 setup on a Special with the fat 16" in the back. The "ugly" buzz stays away up to about 70-75mph.
... and no, it's no slug. I'm 5'8" and about 150. Bein' a lightweight gives me a good power to weight ratio. :smoke:
I’ve run the following combos,
17/34
17/33
17/32
17/31
The two bigger rear sprockets give more snap off the line, the 34 being the quickest feel for around town riding, but is more buzzy at highway speeds .
The 32 rear is a pretty good sweet spot between acceleration and reduced revs at speed. I actually ran this combo the most.
The 31 rear gives your bike a long legged feel, it drops the revs considerably at highway speeds and makes the engine less buzzy. The only weakness I found with this, is if you’re riding in steep mountain grades. I had to downshift one gear to pull the grades. The bike did just fine, but I had to rev it a little harder on the really steep grades.
As others have mentioned, I would stay away from larger front sprockets, cause you can grind your case.
I have the luxury of two XS650s. One with 17/34, the other 17/33. There is a significant difference in both acceleration and comfortable cruising speed. I’m over 200 lbs and I operate an Eleven Special in the mix. All of that comes into play. Currently, the 17/34 equipped bike is getting the most use. FWIW
I should add an important fact. I don’t have much need to drive over 55 mph. Not around here, anyway.
I like driving the bike at 3500 RPM. 17/33 is OK for me, any taller is too much a slug. YMMV
I'm with Marty.
I run 17/33 on my Tracker with 18'' rims.
Little problems with Vibes; and good acceleration to boot.
Cruising at a steady 70 mph is fine.
I like 17/32 on a 16" wheel, 17/33 on an 18". I tried the 32T on the 18" wheel and didn't care for it. It loses too much of the take-off power in the lower gears.
I'm with Marty.
Ok good info on the rim size ! I run an 18 as well
750cc through 17/32 driving an 18x2.50 rim with a low profile tire, pretty good all around compromise for me. Any sustained speeds much about 60-65 and the XS650 isn't the best tool in the shed.
Oh, I agree , there are better tools certainly! If I’m long legging someplace, I’m taking an F650 bmw
There are a few 65mph sections I run if I’m going to work with the XS, but no more than 15 minutes-ish
Most of my riding is 30-45 mph gravel , a 33 seems to be the best combination I’ve seen a I weigh all the responses here
Any suggestions as to where I can find a 33? Is that a Mike’s XS item ?
Both of my bikes are basically stock, just with the routine "pods and pipes" mod. One is ported though, and I feel it does run a bit stronger because of that.
Thanks. Mine is going to be 700cc with a Shell #1 cam, ported head, VM34's and pipes, plus it's going on a diet, which it needs to to compensate for the fact that I won't. I'll probably buy both a 33t and 32t and just see which one feels best, and I'll stick with a 17t up front.
With the extra grunt from your lighter bike with a hotrod motor I would guess you wont notice a lack of performance between the 32T and 33T. My 750 Tracker has 18/34 and when I need replacements I may go 18/33 or 18/32. The down side going to far is low speed (parking lot) manuevering become more of a challange.
Now if I could just get the weight off of me. I can't really take the cut off wheel and de-tab myself.
