fullercameron
OK. Got the new coils put on and the bike started right up on the first kick with no choke. It was running good, so I left the choke off and got the bike warmed up a little bit. Since I recently pulled the clutch apart, I went to pop it into first to make sure that the clutch was working properly and it stuck and died.
Turned the switches off, since it felt stuck again, I put it into third and was able to feel it pop loose and I could then roll the bike in gear with the clutch in without the engine turning. After freeing the clutch, I went to restart the bike and it wouldn't start up.
I checked the plugs and they still appeared bright and clean. Possibly a little carbon on the insulator, but the electrode looked spotless - then again it was only running for about 2 minutes. It smelled a bit gassy so I let it air out a bit and tried again. One pop and then nothing. Pulled the air filters and noticed a bit of gas on the inside of the lip of the air filter.
I believe that the problem is probably my float level. I pulled apart the carbs to clean and check jetting because of the older choke problem. I reset the float height but found myself without a rule with metric measurements at hand, so I used did a little conversion and set the float height with a regular standard rule.
The fact that it started so easily without the choke leads me to believe that it is running rich, I have read that the float bowl height can lead to a rich condition like this and the more I think about it, the more I distrust my standard metric conversion and float bowl height.
Does this sound like I'm thinking straight to anyone?
I also though that since it started so quickly today after the carbs were recently off, and didn't after the petcocks were open for a couple of minutes might indicate that it took a minute for the bowl to fill up enough for the height to be a problem.
I also rechecked the jet sizes on the bike since the PO had been running a 750 kit that was removed. The old pilot jets were pretty chewed up and really plugged so I ordered new jets, but mike's was out of the stock pilot size so I went up one. I am running pods and more open pipes, so I thought this would not be a huge problem.
Does anybody think that the problem lies in the new pilots and not the float height?
I'm pulling the carbs off again as soon as I get a minute and was hoping for one more kernel of advice. Running, not-running, running, this is getting frustrating. I feel like I'm close enough now that even though it's 100 degree outside here, I put on my boots and pants every time I go over to the shop.
Maybe this weekend.
Putting a picture of the bike on this one. A friend helped me finish the seat about 2 weeks ago and I just took some new shots the other day.
Maybe this weekend.
