fullercameron
Have been reading through multiple posts about this topic, but haven't been able to solve the problem yet. If this is covered somewhere and I didn't see it please let me know.
I've got the bike running and it sounds reasonably good. I have been through the carb guide multiple times and was hoping to begin syching and adjusting in earnest but I can't get the bike to run with the choke off.
It starts on the first or second kick usually but after a couple of minutes at idle, when I reach down to switch off the choke the bike immediately dies. It is idling a bit high (around 1500) throttle was causing a bit of popping on engine deceleration but after double checking timing, valves, point gaps, cam chain adjustment and plug gaps, throttle seems to be responsive and returns to idle quickly after a blip on the handle - only with choke on still.
I've got the carbs off again and I am re-cleaning and checking float level, etc. The PO had upgraded to a 750 kit years ago, but in going through things, I ended up replacing the cylinders and going back to the original 650. Checked to see if he had re-jetted the carbs, but they still have the 130 main and 42.5 pilot that came stock with the carbs from 72.
I am running aftermarket turnout mufflers (that came with the bike) and pod filters from mike's XS. I was hoping someone might be able to give me some advice that would allow me to run the bike without the choke so that I can see about getting things straightened out. Plugs are reading rich (carbon black), but this seems right since I am unable to switch off choke.
Since this problem is at idle, I assume that it is a pilot circuit problem but that is as far as I am getting. My guess is that when the choke is switched off, it leans the mixture to the point that it can't run. Does this sound right?
I ordered a size larger pilot jets to test, but would like to see if someone has some advice before I start really tweaking things.
I'd appreciate any help. Still in the process of learning to be someone future owners don't curse for my mistakes and this forum has been a great help.
Thanks
Thanks
