Opinions on Design Wanted: Good or Bad Fire away
T3chnic4l
T3chnic4l
Minnesota
Hey, pretty simple I'm looking for some input on my battery location. It's housed in a pretty snug fitting rubber lined box a friend welded onto a triangle plate as pictured. I Can't decide if I like it or not.
Also I'm trying to decide where my starter relay should go. I could locate it right in front of the battery or right below it on that plate. Looking just for opinions so fire away guys.
Finally How should I mount my ignition coil, Because of the tank swap its going to show I'm stumped on what would look good. I've got a bunch of photos attached so you can get a good idea of the look I'm working on.
First of all, I love that tank. Well worth the effort to build a bike around it.
You could move the coil and mount it vertical under the triple tree, then grind the brackets off the bar that runs under the tank to clean it up visually. I wouldn't cut that bar off though.
As for the relay, mount as much as you can underneath that battery box. The lower, the better.
