little_ryle_13
OK this is my first 78 XS and first Carb orator powered anything. On top of first pma/pamco system I've dealt with and I'm kind of stumped. With that said I rode the bike for three hours the first day I got it and it died on me at a traffic light. Pulled off tried to get it to start back up and nothing. Changed spark plugs again nothing. Next day pulled the carbs PO surprisingly cleaned them, but I took a stab at them anyway. Put them back on bike would fire up but die after a few seconds and immediately when given gas. The wiring was a little cruddy and not much to it so I rewired it today. It finally ran for a minute today could give it throttle but backed fired a little. So in the time it was running we noticed it wasn't firing on both cylinders just the right side. Swapped plugs around but couldn't get it to run long enough to see if the left side was firing now and not the right. So I tested the primary ends on the coil and got 4.5 ohms which I've read is correct. But when I tested center of plug terminals it didn't read anything. Also tested from primary to center of terminal. Got nothing. So my question is is my coil bad? I searched for similar problems like mine but didnt find a definite answer. Anymore ideas at what it might be.
