79Standard
Been chasing idle issues for a while and narrowed down to a worn out and sticky ATU. Tried new springs from Mikes and couldn't get the proper tension, plus the weights were pretty worn anyways. Figured I'd go with a Pamco E advance since I've already got the ignition and love it.
Anyways, the bike will start, but to keep it running the sensor has to be all the way advanced and the idle screw is in much further than it should be just to keep idling.
Any ideas? I have 60 degree rotor, both pins are there for the advance replacer thing, and it worked fine (except for the sticky advance) prior to installing the e advance. I seem to remember seeing a thread a while ago with the same issues, but can't find it any under of the search terms I've used
