MiniDanzig
hey you guys, i am hoping someone can point out something i am doing wrong. i installed my Pamco ignition today and attempted to get it running on a battery as per Pamco Pete's advice in several threads. the directions from Pete were as follows:
1. Connect the red wire from the PAMCO to the battery positive terminal.
2. Connect the green wire from the PAMCO to one of the coil terminals.
3. Connect the black wire from the PAMCO to the bikes frame.
4. Connect the negative terminal from the battery to the bikes frame with just a clip so you can use this as your on off ignition switch.
i followed these directions, wired as pictured in my diagram below, kicked and kicked but no signs of life. is there something obvious i am doing wrong?
notes:
1. the battery was not fully charged, somewhere around 8V. i cannot get it to fully charge after sitting for a season. the battery was nearly brand new from Mikes before sitting for a few months.
2. carbs; sat for about 9 months indoors, but ran perfect before that. i know this could be my issue, but i got zero signs of life from kicking setup as shown so i would just like to rule out any other possibilities before ripping into the carbs.
any help or ideas would be greatly appreciated, i am not sure where to go from here.
notes:
