pa-powerstroke
On The Edge
I have the engine from a 73 TX650 that Im parting out, tell me what you are looking for and if I have it you can make an offer. Pics upon request of part. I don't have any carbs. Mileage unknown.
-Cam, Same as what is in the XS1
-Crank
-Transmission
-256 Connecting rods, seem to be in very good shape, very little side to side play.
-Both stock coils, no plug wires
-Good stock jugs, one sleeve is cracked, would need new sleeves
-Points ignition
-Oil feed tube
-3 pistons with 4 wrist pins, I believe they could be used with new rings, not sure what size, believe they are stock
-Early single piece clutch pushrod
-Stock charging system, stator and 2 alternator rotors
I also have the head, rocker cover, cases, case covers, jugs with sleeves that will need honed/bored, tappet covers, ect...shoot me a pm if you are interested in anything.
-Crank
-Transmission
-Points ignition
-Oil feed tube
