taggat
Can provide pictures or measurements upon request.
Most parts 20 dollars or less!
Im not greedy and Im out of storage space.
75 CB750K5 Tank orig paint but dented and rusty.
75 CB750K5 Front fender.
75 CB750K5 Rear fender.
75 CB750K5 Swingarm
75 CB750K5 Oil tank with hoses
75 CB750K5 Speedo, works but rusty
75 cB750K5 Tach, works but rusty
75 CB750K5 Front rim with rotors, rusty
75 CB750K5 Rear rim with drum
75 CB750K5 Rear Axle
75 CB750K5 Front Axle
75 CB750K5 Forks, rusty
75 CB750K5 Rear tail light mount, pitted
75 CB750K5 Left hand switch housing
75 CB750K5 Right hand switch housing
78 XS650 special Seat, needs recovered.
79 xs650 standard seat in nice condition, no hinges or hardware
78 xs650 front caliper mounting plate
78 xs650 rear caliper mounting plate
78 XS650 sprocket, its slighty wore
78 XS650 Air boxes
78 xs650 rear fender good shape
78 xs650 rear caliper, good working condition
78 xs650 starter, good working condtion
78 xs650 alternator, low charging issue does charge at 2k+ rpm
78 xs650 regulator
78 xs650 rectifier
78 xs650 battery box, with rubber gormets
79 CM400T Rear Fender, good condition.
79 CM400T seat, condition is very good.
80 CM400T motor, complete 4k miles on it
80 cm400t carb bank
80 cm400t air box
80 cm400t headers
80 cm400t coil
80 cm400t cdi
82 cb400t motor, complete 20k miles on it
82 cb400t carb bank
82 cb400t air box
82 cb400t wiring harness
82 cb400t ignition with key
82 cb400t headlight
82 cb400t headers with manifold
82 cb400t triple tree, complete
82 cb400t forks, straight
82 cb400t front fender, nice
82 cb400t frame, bill of sale provided
82 cb400t swingarm
82 cb400t coil
82 cb400t cdi
82 cb400t speedometer
82 cb400t tachometer
82 cb400t rear brake light
82 cb400t rear fender
82 cb400t throttle assembley
82 cb400t cables, clutch, tach, speed, throttle push and pull
82 CB900F triple tree, complete.
82 VFR500 Interceptor Triple Tree, complete.
82 VFR500 Interceptor Swingarm
82 VFR500 Interceptor Front rim with rotors.
82 VFR500 Interceptor Rear rim with rotor and sprocket.
82 VFR500 Interceptor Forks, straight.
82 VFR500 Interceptor Mono shockS, one good and two for rebuilds.
93 CBR900RR dash, tach, speedo cluster.
93 CBR900RR nissan rear caliper, seems froze
honda shocks, a few different ones to choose from
harley slip-on exhaust mufflers, used, dinged, clean up well not show quality, 40 bucks
Sissy Bar Backs a few to choose from
different handle bars 7/8", no drags or clubmans
Unknown year suzuki gs550l tank, dinged, rusty with petcock
Unknown year honda tank, believe its a magna tank, rusty, dinged, no big dents, no petcock
Unknown year gsxer forks, straight
keywords; harley, honda, yamaha, triumph, parts, cheap, trade, motorcycles, basketcase, bobber, chopper, brat, build, project.
75 CB750K5 Swingarm
78 XS650 Air boxes
78 xs650 regulator
78 xs650 rectifier
80 cm400t carb bank
80 cm400t air box
80 cm400t headers
80 cm400t coil
80 cm400t cdi
82 cb400t carb bank
82 cb400t air box
82 cb400t headlight
82 cb400t swingarm
82 cb400t coil
82 cb400t cdi
