chayko
I need the following parts for a drum brake rear wheel/brake assembly.
1 rear wheel spacer - goes between the brake backer plate and the axle adjuster
1 rear brake pivot shaft and arm - goes thru frame - one end splines to brake lever other end has arm to
mount to brake actuating rod
1 brake actuating rod goes from brake arm to arm on brake backer plate
Will buy outright or swap for rear disc brake parts - I am swapping out a rear disc rear end to a drum brake rear off of a TX750
Thanks for looking
Thanks for looking
