panman142
Ok, back to the forums once again after a long night of swearing in the garage...anyways, I just got my *slightly* used Boyer ignition system (courtesy of another member from this site) installed tonight, or what i thought was installed. First issue is with a fully charged battery, i went to hit the electric start button and have nothing. It was intermittent before, but now there is nothing at anytime. Next problem, I went to kick it, hoping that the magic of Boyer would fix all my problems, and still it wont start or even sputter or smoke or anything. I have the timing set per instructions and also wiring hooked up as it called for i believe. Ground is grounded to the old coil bracket and the red wire from the old coil is spliced into the boyer so it has switched power now?? Also, with the key on and the bars turned all the way to the left i hear a clicking sound that apperars to be coming from the boyer system? Noise only happens when bars are hitting the bump stop on the frame. At this point, any help on anything would be great. Hopefully I can finish up this damn project before the entire riding season is gone :/
