bloodthirstysystem
over the weekend i built the $6 rectifier for a '78.. took it out for a spin and while cruising at about 40mph the bike shuts off.. i check all the wires for loose connection, nothing. starts right back up. a couple minutes later the headlight gets dim (it was dark out) while riding at about 3000rpm. it died two more times while trying to get it home.
i used needle nose for heat sink while soldering the rectifier, so i shouldn't have burned out the diodes.. does it sound like the rectifier? maybe the regulator died all of a sudden? i do not know the symptoms of a bad rectifier on a running bike.
