I believe the screws are 6mm. I’m not sure on the spacing. I know Pingel makes some blank mounting plates for you to drill yourself. You’re right about the cost though.
I think this goes to what 2many said above, if you don't have a pre-petcock filter, gas tank grit will eat your fuel valve. Eventually the gas will eat away, harden, leach the plasticizers out of the rubber.
I used a dual outlet Pingel with a home made adapter plate for 77 and earlier tanks for a couple of years, never leaked or gave trouble. Bought it cheap, would let it go cheap to a good home. PM if you're interested.
YEOW!!!!! Boy, are those things spendy!!! There's got to be a more economical solution to keeping the fuel going where it's supposed to (and where it's not).
...more research is in order.
That adapter plate itself goes for abouts forty bucks plus, leaves the petcock around seventy plus.....that price is right. I did something similar many moons ago but with a dual option input petcock with on, off and reserve. No regrets.
