jonboy-xsbobber
Hi I have an 81 stock ignition just changed cam chain guid and tensioner new pistons and rings. After it started up second kick but I was having problems with my left cylinder missing popping and back firing at idle I was going to get my stock carbs rebuilt but went with a set of vm 34 round slides from tcbros. Put them on with new uni filters started first kick. Right cylinder runs great with the new and old carbs. Took it down the road and back it seemed to run better but still had a miss in the left cylinder mainly at idel. Went out today and it didn't want to start but when it finally did the left cylinder didn't seem to be fireing at all except for a loud back fire every few seconds that sent smoke out my air filter. I swaped the plug wires to see if it moved to the right and it didn't. The left plug looked wet when I checked it I put a new coil wires and plugs end of last summer. I adjusted cam chain and valves after rebuild.
It just seems to be getting worse could it be a jetting or a syncing problem? (Uni filters and open pipes)
I have looked on here and found some info but would like to get some help directly if possible I am trying to get it ready to take to ohio in August and I'm running out of time and money and help wound be greatly appreciated
