Tron
Bearded Sheep Whisperer
Hey all,
So I just recently got my ride back on the road as some of you may know..
I swapped over to Hughs PMA and Pamco petes ignition.
Running a capacitor, no battery, kick only, minimal wiring with a fuse block in a little tray etc etc. Green monster coil..
Anyways.. SO My bike basically just shit itself and died, leaving me stranded in the middle of no where, with a tow bill. The reason I switched over from the stock charging system/tci to what I have now was for reliability. Yes, the old system worked fine, but I didnt trust it. A bit ironic isnt it??
When the bike died, I waited a few minutes, and it kicked over again than coughed, sputtered and died. This happened about 3 times and then it wouldnt start at all.
We tore back into it, checked the ignition which was fine, put a battery in and bam, fired right up. Once the battery died from being run for a little bit, we knew right away it was the charging system. With a multimeter, we saw that the battery was at 12.3V, and as it kicked it was back and fourth between 11.8-12.7.
I pulled the rotor, saw the connections weren't perfect, so I resoldered them up, got it back in and its still a no go. So now its either my reg/rec or possibly just a shit alternator. Can anyone help me find an answer so I can get this thing back on the road and running again? Im looking for ways to test the reg/rec, and rotor.
Basically, Im running out of patience, time, and money, and I lose my shop in 3 weeks and will no longer have anywhere to continue fixing shit that is supposed to work in the first place.
Help?!
Help?!
