Ran great for a few day's then it started backfiring and the point's had closed up. Looks like I did not fit spring washers when I fitted the new point's, so I installed them and also noticed a 1-2mm side play in the advance rod and slight chamfering of on the outer edge of the point's lobe in two areas but not the entire circumference where the left set of point's pad rubs on the lobe. I installed a spare advance rod and lobe which removed the side play and the lobe has no chamfering on the outer face. Reset the point gaps to 016 with the feeler gauges, dwell meter showed both at 32/ 33. Gave up and started it, runs fair but when I went to turn the choke off I got shocked when my finger touched a bare section of throttle cable where it has been rubbing on the fuel tap??. Looks like i will be taking the fuel tank off tomorrow after work to find where the throttle cable is arcing?.
