Stickysteve44
So I went to work earlier in the day. Bike ran fine. When I was leaving work, it started to pop and sputter until it fully warmed up.
When I left for work it was 95 and sunny. Leaving work, it had been raining and was down to 77 degrees. Maybe the low pressure system coming through had something to do with it? It's a mostly stock 1982 Heritage Special. Only difference is the K&N filters. One up on the pilots, and mains. Oil (10w-50) was lowish but still between the two lines. Just went through the basic maintenance arround 150 miles ago or so ago. Adjusted cam chain, valves, mixture, synced carbs, drive chain, and changed oil. Carb boots seem pretty decent. So I don't think it's a vacuum leak, but I'll check.
What y'all think I should look at?
