XSGLENN
Alright guys I'm pretty good at figuring stuff out on my own, but I've ran into a real head scratcher here. First off let me give you a detailed list of the bikes setup.
-1980 XS650G with TCI Ignition
- Mikesxs 2.5ohm tci coil part# 17-6803, NGK Iridium bpr7eix, NGK 5k resister caps 7mm wires
-Stock alternator in spec, good battery (12.8v with motor off, 14v at 3000rpm)
-new fuse panel, ground wire / frame sander and re-torqued, all wire harness connectors cleaned and sanded
-removed ignition box to re-solder board
-bs34 carbs rebuilt and tuned
-stock pipes and air box
-aftermarket ignition switch
While sitting at the red light my bike decides to die on me. I pulled her over to the side to take a look at the problem. While pushing the bike I noticed all dash lights were off. I checked the fuses all was good. Turned the ignition switch back on unfortunately I don't remember if the dash lights came back on at this point. Proceeded to kick the motor over a few times..... nothing. Then tried the starter... still no go, not even a sputter. I set there around 5 mins or so then tried again. This time the old girl started with a half ass kick and drove home from there with zero problems. Now a few weeks back I went out to ride and noticed when I turned on the switch the dash lights did the same thing. I checked voltage and all was normal. Kicked over the bike and the dash lights came on, but took another kick or so to get her started. Has anybody else ran into this problem, because I don't have a clue where to begin?
Thanks for any help, Glenn
