Aweebaweeba
First off, let me apologize for the length of this post... I am trying not to leave out any detail of what I now call my "XS650 Odyssey".
I bought a 1983 XS650 Heritage special. It ran badly when I first got it, was hard to start, and showed obvious signs of carb trouble. So my father and I got to it, ordering a few parts from mikesxs.
The first thing we did was clean the carbs out, replace the needle and seat aswell as change the gasket. The seats on one side was so gunked up, it was crazy. We replaced the rubber o-rings too. Once we were finished with that, we tried to fix the starter with mike's repair kit... This required taking the clutch off, which we did. Once the new gear was in place, we put everything back together, tested the starter and... nothing. It still spun right off, giving maybe half of a full crank before letting go. Nevertheless we pushed on, put the gas tank back on and tried to get her to start. We also fixed the air/fuel screw, which was adjusted way fucked up (one of them was at 1 1/2 turns, the other at 2 3/4 turns, set them both to 3 turns out from the bottom as per information found online). We cranked for 20 minutes, no go. We then tried to bump start it, and after spraying some fuel directly into the cylinder, she started, and started strong.
After she ran for a while we started asking ourselves why it wasn't starting easy. I looked around and found out that when installing the gasket, I left one of the holes unopened which did not allow fuel to enter when starting. A-ha! So we took the carbs off, corrected the gasket, put the carbs back on, and as soon as we connected the gas line and turned the petcock on, fuel started leaking out of the airbox. Shit.
After a brief search online we found out that the float height may have been all out of whack. When testing with the two tubes connected to the bottom of the carbs, we found that one of the carbs (the side that the fuel was leaking out of) was adjusted way off. So we took the carbs off and adjusted that float (One float ended up being set differently than the other, which I thought was strange. I can provide pictures if anyone is interested). We also tested to see if the floats were puncutered/leaking, no bubbles. So now when testing with the tubes, both float levels were just where they needed to be (can provide pictures for this aswell, in case I am mistaken). So then we put the gas tank on, started cranking, and nothing. Since the starter was still shot, we tried bump starting, and she wouldn't even try. She would backfire every once in a while, too. At this point I am very frustrated. Still too much fuel getting to the carbs?
The only other thing I can think of now is a bad spark, but we verified by kicking with the plugs out and sure enough, after gapping them to the correct height, the sparks were visible, and the spark leads were clean.
What's next? I'm thinking the ignition coils may be weak. What sort of test can I run to see if they're done? Can you guys suggest anything else for me to try? We're already halfway through may and the bike still won't start easy, and the most frustrating thing is that once she is running, she runs so smooth! Idles perfectly, doesn't burp or backfire once warm, and the throttle is very responsive.
You guys have been very helpful already, I feel blessed to have this forum as a resource because it's helped us so much with all the kinks we've run into so far. I really hope I can find an answer here because I'm starting to lose my fucking mind with this bike not starting.
Thanks in advance.
Thanks in advance.
