cleoncleon
Long story short, my PMA fried my Pacmo.
Running the Banshee Mod as opposed to the HHB kit.
- Banshee Flywheel
- VF500 Reg/Rect
- ZX6 Stator
- w/ SParx Cap.
I've contacted Pete, solid dude, he's gonna help line me up with a new plate, but till that comes in.. How on earth did it happen???
NONE, of my fuses were blown.. Have one 20 amp fuse right BEFORE the capacitor and a 7.5 amp fuse before the ignition. Neither of them popped, and my Pamco fried.
So, I take it fuses don't necessarily look for spikes in voltage but in amperage?
How are your Banshee swapped systems not blasting your Pamco's to hell?
Im thinkin' I need a new regulator/Rectifier? seeing as that is what regulates the unused volts to heat..
The VF500 one seemed to work alright.
Like a dunce I didn't check charging volts on first startup with the voltmeter.. But, now that we know i'm charging excessively high. Is the regulator to blame?
That my VF500, I doubt it's my wiring, but, let me just make sure..
This Reg/Rect has two leads of Red cable and Two leads of Green, with one black in the middle. Black is unused. I'm assuming the each red/green pair in the hot/ground for both the Reg. mechanism and the Rect. mechanism.. I spliced the green together and grounded them. I spliced the red together and connected both to the 20 amp fuse line then that one line as a hot to the Capacitor.
Using this diagram. Except I put a 20 amp fuse before the Cap. on one Hot Terminal prong, then used the other hot terminal prong to connect the system to the Cap. with.
- Banshee Flywheel
- VF500 Reg/Rect
- ZX6 Stator
- w/ SParx Cap.
