TeeCat
One-Mik Wonder
Hi, guys...
I replaced my bike's front brake lever and perch when I replaced my master cylinder, because they are integrated. The clutch lever and perch are working okay, but the pivot holes in both are a little worn, so I'm expecting arrival of a new lever and perch this afternoon, and will be installing them within the next few days.
I have adjusted my bike's clutch many times (at the lever and the case cover). But if I'm just replacing the perch and lever, can I get away with undoing just the bar end without disturbing the adjustment at the case cover, or will I have to do both? I'm not sure if there'll be enough slack in the cable if I do just the bar end.
Also, if I have to do both, does anyone recall the size of the clutch adjustor locknut? (I don't have the bike in front of me.) 12 or 13mm, isn't it? I need to stop on the way home and get a little offset box end wrench... those things have a way of tottering off...
Thanks!
TC
Thanks!
TC
