- Messages
- 683
- Reaction score
- 1,477
- Points
- 143
This is my 1st thread creation, so correct me if I'm wrong.
This has happened a few times, but it always corrected itself. it runs great, plenty if power, then it appears to run on 1 cylinder, but it's sputtering in the other. 1/2 or full trottle, load or no load, still runs like doo doo.
So the other day it happens,so while riding, i yanked up on each butterfly separately and determined that the right side is the problem. I limped home and parked it.
30 minutes later, before starting it, I tapped the bowl cover with the plastic end of a screw driver. it stared and ran great. Almost better than ever.
It happened again about a 1/2 hr later, and with my trusty screwdriver in pocket i tapped while riding and it cleared up again.
It seems to happen during hard throttle.
I'm guessing that the float needle is sticking closed when i drain the bowl at wot. I've replaced both needles 4 years ago. Could the alcohol in the gas be doing this, (not flex fuel ready), or do these needles wear out fast? Or is it a piece of rust that keeps moving around, clogging things randomly?
