Really bright lights?
PHeller
Erie, PA
Erie, PA
Anyone got some really bright turn signals or brake lights?
Pictures? LED or Bulbs? Modified or bought that way?
Posted via Mobile
Just finished re-reading a very good thread that was just bumped up.
"1157 led " check it out. Not very far below your thread.
Cool, noted. I however am looking for options outside of stock lighting. Though the 1157 turn signal bulbs can be quite bright.
Posted via Mobile
I don't like LEDs because in use they are only a distinct spot instead of lighting the entire brake light/taillight lens.
Try out a 2357 bulb. It will fit the 1157 socket. The taillight is the same wattage but the brake light is 7 watts more than the 1157. Doesn't sound like much but it is noticably brighter when you hit the brakes. I like to 'wake-up' those following me.
Tom Graham
I've swapped DOT LED fixtures, both using the original housing and by cutting the boards out and fixing them to the stock tailight lenses. No problems after 3 years.
I'm thinking the $5 2" clearance lights at HF could be robbed of the boards for turn signal replacements.
