Rear disc/forward controls
jdxs
ohio
So the easiest way to link up my rear master and forward controls has my master sitting outside the frame rail a bit...I know this will work but not sure it looks the best. I know I could use a pivot to bring master in a little bit but either way something will be sticking off the frame to meet linkage rod. What do you think about doing it this way or should I be looking at a different master with a pivot?
A lot of people use the stock brake pivot shaft. The rod from the pedal hook to one side of the pivot shaft, the pivot shaft lets you transfer the master to inside the frame.
Thanks for the reply..Ya I have been toying with that idea as well because it gets master moved into frame. But just adds more moving parts which is why I thought about eliminating the pivot and go straight to master. But I think the best option is probably like u said.
Just wanted to update and post pics of what I ended up going with incase it might help someone else looking for ideas.
