roadstar06
Here I am again with the same problem! I found the correct spacer needed #11-3h3-25377-00. so I put it on yesterday and caliper mount if still rubbing disc, only thing I can think of is lack of pressure to caliper piston to push it over 1/8+ or so to center rotor on/with caliper. another Q: is there supposed to be a thick flat washer on / before crown nut? doesn't show one on factory blue print, Is there a video anywhere on this planet showing the assembly or disassembly of this wheel? will have to tear it all back down if I don't get an answer fairly soon, which leads to another Q: is there a way to remove seals w/o jacking them up?
