I'm looking for a couple parts to button up the '75 I picked up a couple weeks ago and I am in need of an entire rear brake linkage. At least the pedal, pivot shaft, and the splined links that attach to both the shaft as well as the drum itself. Since the swingarm has been extended I will be making a new pull rod.
For some reason or another I had a pair of BS38's from a '76 and need a single cable throttle to eliminate the extra cable.
Edit: Also looking for a choke lever and choke lever spring for these carbs. I think that's the best way to describe it. The piece of spring steel that holds the choke in the on position.
In the spirit of a budget build I am even entertaining the idea of picking up a pair of carb holders if anyone has a good set laying around. Otherwise I will be ordering new from either JBM or Mikes.
I'm located in Long Beach, CA 90802
