kelso
I am using a 78 motor with a pamco and wiring from scratch. I need a reg/rec and from what I see they are separate on the 78. There is a reg/rec on my 1980 that i'd like to use. I was trying to figure out if there were any issues with using the one off of the 80 and I noticed that the reg/recs that mikesxs sells are different part numbers for earlier and later years (pre and post 79). I am thinking that this is only because of the wiring setup on a stock bike and that it shouldn't matter since I am starting from scratch. Any thoughts?
Mikesxs reg/rec for 1980-84 is part #24-2087 and it says that it is not for use with older models.
78-79 models are part #24-2089 and it has this disclaimer
Note:
This Rectifier/Regulator is sold only for use with stock 1970-79 wire harnesses.
If you are purchasing it for use on a chopper or custom, please note that we can't
accept returns for any reason due to the possibility of it being incorrectly installed.
Note:
