Tim of DO THE TON
XS650 Junkie
I'm prepping the clutch cover for some media blasting and want to get the oil pump out to inspect etc.
I've pulled the tach drive shaft out, and removed the 10mm nut on the worm gear, but for the life of me I can't remove it or the larger gear driving the oil pump.
The pump itself seems seized - this clutch cover came off an engine I completely tore apart and rebuilt (750 rephase) but I used my existing known-good polished clutch cover on that engine.
Building another engine and this is the only clutch cover I have. Removing the oil filter cover revealed LARGE metal shavings. The engine had holed pistons - was a real disaster.
Regardless - any thoughts? Can't get this gear off to save my life to expose the screws holding the pump in.
