pnedac
I see that the simplified wiring diagrams on the "some wiring diagrams" (5th one down the page)page, particularly the 81 XS simplified one that looks oh so simple, appears to be without the TCI.. It has the coil, ignitor unit, pickup coil, but I do not see that it has that little black box under the battery that I believe is the TCI unit.
Is that correct?
Furthermore, I see that the diagram has what looks like a ground coming out of the positive batterty where it says "power outlet". What is that?
Lastly off of the rec/reg there is a greeen and a brown that appear to go to a small, unlabeled square. What is that?
I rewired my 77 XS without too much trouble, but this 83 is a bit different and I want to make sure that I am including everything that will be needed in order ot make it work. I know that there will be at least 2-4 components that will not be needed per the diagram.
The bottom line reson is the PO had the wiring so F'ed up that absolutely nothing worked right and I figured it would be best to rewire it myself for modernizing purposes and peace of mind that I can figure stuff out later.
All help is appreciated!
Cheers,
Pnedac
Is that correct?
Cheers,
Pnedac
