Kansas City, Mo.
Can you alter the polarity of the field by running the current in the opposite direction?
Yes.
Troubleshooting.
I'm not going to try to reinvent the wheel here....The following is from the charging system guide in the Tech section. Thanks @gggGary
1. First charge your battery to at least 12.5-12.7V.
Is the battery Good?
Will it hold voltage overnight or longer?
Will it light a turn signal or other bulb for 15 or 20 minutes and still have 12 volts?
EDIT by me: A good battery will run the headlight on low beam for 20 min. with only about a volt - volt and a half drop.
Is the fluid at the correct level? Use ONLY distilled water to refill if needed.
If the battery is questionable buy a new one. A too small battery can be a problem, while idling the charging system will not keep up to the load of a headlight ,tail light, ignition etc and the battery will slowly discharge. Small batteries discharge faster. Yamaha calls for a 1200 RPM idle speed is to keep the battery charging, a too slow idle won't keep a battery charged.
A good charging system won't fix a bad battery, and a bad battery will break a GOOD charging system.
A VOM (Volt Ohm Meter) is needed, It doesn't have to be fancy. One can often found at the hardware store, home center, farm store, auto store, electronics store for less than $10.00 Either analog (a meter with a needle) or digital will work . The digital are easier to read and they auto range so you don't need to pick a range You just need to know what you want to measure ,DC volts and Ohms are the functions we will use most. A diode test function is nice but not a "must have"
EDIT by me: Forum member @I am Carbon compiled some Youtube videos on how to use a multimeter into one thread. If you're shaky on using a meter, I suggest you have a look.
A jumper wire is nice to have. About 3 foot long, 16 gauge wire or more (14 is heavier than 16 in wire gauge) two alligator clips or a solderless lug U and an alligator clip are handy ends to have on it.
Normal hand tools. Flat and good philips JIS screw drivers, wrenches etc. When loosening screws push firmly in, then apply torque. Do not strip the heads. Some of the screws may have been machine tightened 3 decades ago. If you don't have one a hand impact driver is a real time and money saver.
Does my charging system work?
Start the bike, shady area is nice, point the headlight at a garage door or wall, rev the engine, does the light get brighter and then dim a bit as the engine goes back to idle? If it does you have at least SOME charging.
Stock, 1980 or later, and the headlight doesn't light at all?
You may not have any charging, the headlight is controlled by a relay that is powered directly from the stator, no charging, the relay won't close, no headlight.
2. Find a really thin feeler gauge like 0.010" or 0.015" or a wrench, steel ruler, a putty knife, or any chunk of steel that can be lightly held near the alternator cover works too, see picture) and hold it pointed down about a half inch away from your generator cover on the engine. Now turn the key on. If your regulator and rotor are working the feeler gauge should slap the case when the magnetic field is created in the rotor. If nothing happens or the magnetic effect seems really weak then go on to the next test.
EDIT by me: Here's a quick video on how to do the "slap test."
3. On the solid state regulator models (1980 and newer) all you need to do is locate the green wire at the regulator plug and make a jump from it to ground. That bypasses the regulator and allows full battery current to flow through the brushes out of the rotor through the green wire to ground. That causes the rotor to make a stronger magnetic field which in turn causes more current to flow in the stator. If your battery terminal charge voltage jumps up to 14.5VDC when you rev the engine then the regulator or the ground connection for the regulator is your problem.
4. If nothing changes then it's time to check the voltage on the brown wire (It may be black on your bike) at the positive brush with the key on. It should be very close to battery voltage. The brown wire that feeds the brush gets its power from the brown wire at the keyswitch. If you don't have battery voltage at the brush then check the voltage at the switch connector while it's plugged in, by probing from the backside of the connector with the key on. Again you should see the same voltage as the battery. If you do get full battery voltage there then repair the brown wire circuit between the switch and the positive brush. If not then the switch is either bad or the red wire from the battery is not passing the full current like it should. If that's the case then keep going back along the red wire, through the main fuse until you find the source of the voltage drop. No more than 0.3 VDC drop is acceptable. Note* any more of a voltage drop could overcharge your battery... overheating the rotor in the process.
5. Once you have full voltage to the positive brush re-check the charging voltage to see if you're getting 14.5 VDC or better at the battery when revved to about 3,000 rpm. If you still don't have a charge then do the feeler gauge test again. If it slaps the case your rotor and regulator are working and you can go on to stator checks. If not then pull the brushes out of their holder and use an ohm meter to test the rotor. Measure the rotor first by touching the tester leads to the brass slip rings. Then take one lead and touch anywhere on the engine that's not painted. For the first test you should see between 5 and 5.5 ohms between the slip rings. On the second test between one slip ring and the engine you should see infinity on the meter. Any reading lower than 5 ohms on the first test or less than infinity on the second test means you have a bad rotor. Replace it. If it tests good then go on to the stator checks.
6. At the stator wire connector locate the three white wires. Use a voltmeter set on the AC scale to test the three possible connections between the white wires by probing from the backside of the connector. (The connector should be plugged togeter for this test) With the engine running at idle you should see about 10.5 to 11 AC volts (Not DC) on each of the three combinations of white to white that you make. If you get a very low reading on one or two legs then something is grounding your stator. If you have high readings on any of the legs (i.e. 16-18VDC) then your rectifier is bad.
EDIT by me: Here's a video on testing the rectifier.
7. If you got low readings on any of the stator voltage checks then unplug the connector and use your ohm meter to check the stator windings. Check the resistance between the three fabric covered wires (stator side) on the side of the connector. On each white to white connection you should read about 0.4 to 0.5 Ohms. If you get a very low reading on all of the three combinations find the single Yellow wire connector and disconnect it. Re-check your stator resistance. If the readings are now good then the yellow wire or safety relay are shorted. If there is one or more that still read low after disconnecting the yellow then check those legs by touching one lead to ground with the other on the white wire. You should see a very high Kilo ohm or infinite reading. If you get a low resistance check the stator lead pigtail to see if it is pinched by the cases or rubbed through on the frame. If that looks ok then your stator is shorted and needs to be replaced.
And that's about it except to say that dirty connections and worn brushes account for most of the charging system problems. Good Luck you'll find the problem.
EDIT 5/31/21: @MaxPete was kind enough to turn this into a PDF. Thanks Pete!!
Back again having another go Tryna edumacate myself which is a very tall order.
IF the current regulator checks out ok,
(bought another 9volt for the multimeter)
If it checks out ok but is mismatched to the brushes, is there a way of matching it to the brushes .
This bike is sorely testing my patience.
Regretting buying it, yeah I should've checked it out better, but with the distance involved I was committed before I left home.
Now Im paying for my poor choice.
Right now I'm thinking get it running well enough to try to cover my outlay.
Going home to test the regulator now
Keep at it. These are marvelous reliable bikes with a little upkeep. All the knowledge is available on this site and in the "Tech" section at the top of the page. Here in the US they are affordable as well. Are they expensive down under?
Can be expensive for a good one(which I ain't got! )....Paid $5600 Aust for it, probly owes me 6K all up now if I don't take time and stress into account.
As luck would have it since I've bought this a couple of real nice ones have come on the market for $7-$8K Aust.
I'll keep at it, gotta even if I choose to get out of it, gotta be running right.
If it checks out ok but is mismatched to the brushes, is there a way of matching it to the brushes (?).
The short answer is yes, either a type A or type B regulator can be made to work with either brush setup. It would require some minor rewiring and/or adding nylon screws to the brush holder.
Seeing as my current regulator passes the test, even though the numbers are a little higher than the two YouTube vids I watched.
Is it possible to explain in simple terms exactly what I need to do to the brush wiring to make this R/R that's on the bike work properly?
The VM 34 Kit arrived today, though with my frame/tank mods I'm sure some items will need to be exchanged to tailor them to suit.
Off to the post office now.
This is posted elsewhere on my original thread as well as the Nylon Screw thread but I'll put it here too hoping @Jim sees it. ....
Ok I've got the 3 nylon screws fitted to the inner brush..Do I leave the one metal screw for outer brush as is?
Presume I do or it'd be mentioned.
Now with all the changing around of wires I've been doing I'm lost as what to do next?...
This is how it stands now.
3 whites go via connector to the the whites from/into reg/rec.
Green from the brush goes to green in regulator via connector.
Right now black from brush is going into rec/reg via connector block.
Brown from R/R is going to switched power.
Is that correct???
I'm gonna start it now and see if there's any charging indicated at the battery.
NO CHARGING HAPPENING!
Where do I go from here?
Christmas has come early for my '76 and '75 !
Rewound Rotors for both of my standards.
This now makes three of my XS650's to have Jim's superb workmanship at the heart of their charging systems.
Thanks Jim !
View attachment 231861 View attachment 231860
My golly that top one (76) is gorgeous. I have debated doing custom paint on my 76, and this makes it harder to resist. Of course I'll never get the chrome so nice, but I can dream.
Thinks I may need to bridge the black wire from brush onto the brown wire from R/R that goes to switched power?
I'll try that?
Just noticed a 'like'
In the end it was.
Metal brush screws
White to White
Yellow nowhere
Green to green brush
Black from Reg to ground
Red from Reg to Bat+ via fuse
Brown to switched power....
Charging at 14.3
Thanks Everyone
Jim , 5twins, jpdevol, anyone else I might've missed👍🙂⚡
A new riding season is almost upon us. Time to fire up the cauldron. Lessee if I remember....
Throw in an old rotor, eye of newt and toe of frog, Wool of bat and tongue of dog…
Say the chant.... "Double, double toil and trouble; Fire burn and cauldron bubble."
Let it simmer for an hour, stirring constantly with a wooden spoon.
...and here we are, a freshly rewound rotor. This is the second one of the season. Another forum member snatched the first one up before it even cooled.
Prices are in comment #1.
I'll note here that this month marks 4 yrs since I first offered this service. Prices ain't changed in all that time. :smoke:
