Hi, I've posted here a few times before, and spent a bunch of time learning everything I can from the forum, it's gotten me through just about everything in bobbing this 81 650.
My problem is that after a full carb rebuild my right side will not run if the mixture screw is anywhere but fully in. When I begin to back it out, right side begins to bog. I'm looking for ideas as to what this is.
Here's what I've done so far:
New float bowl gasket, floats, needle seat, float valve needle, floats, floats set at 22mm from carb body. 144 main jet (xs pod filters and shorty exhaust), 40 pilot jet, new carb boots, new intake manifold gaskets. New mix screws with spring, washer, and o-ring, left mix screw set at 1.5 turns out dead cylindered. New fuel lines and inline fuel filter on non-vacuum petcock, air barbs capped.
I've cleaned the carbs as best I can, it runs well, kicks 1st or 2nd time, but seems a little boggy on right side. I have had problems with plug fouling so that's why I went down a notch on pilots. on dead cylinder right side fires but again doesn't idle on anything but mix screw totally in. It's not quite as strong as left side, and doesn't burn quite as hot.
Any ideas/thoughts? Somehow fuel is getting past the mix screw at idle. No problems running/cruising, etc, though maybe a bit boggy.
PS, Thanks to this forum I found and fixed the ZD4 diode problem in my stock TCI ignition, so no more mystery stalling
