Halloweenie
Bearded Banjo Brawler
I was caught in the rain today on my '83 Heritage Special. It ran just fine, but I felt a couple small shocks on the wet clutch lever. After searching the board I went to double check my grounds, especially the one for my recently installed PAMCO, which is grounded to my top motor mount. After I filed clean the frame where the ground is, I went to try the bike and found that only the right cylinder is firing. I checked for spark and both have a blue spark, and yes I did it with both plug attached to the coil, and just held one to the engine while the other was in the cylinder. I switched out to new plugs, cut and reconnected the HT to the plug caps, still nothing. Did I fry my PAMCO? Did I screw something up by grounding where I did? I am at a loss, and near freaking out because the bike is my only transportation. Please help!
I should add that the bike has never had a problem in the rain before, but this is the first time it has been in the rain with the PAMCO. Also, compression is fantastic and I have not messed with the carbs in a couple weeks and the battery is at 13 volts..
