it LOOKS way advanced, but the timing plate looks a bit beat up
Ok, we can't have that! Timing plate repainted, with new gold leaf markings!
Unfortunately, as you can see, after finding TDC using a dial indicator, I can't slide the timing plate far enough over to line up with that. So I painted a new mark next to better line up with the TDC line on the timing plate. What would cause this? Likely an aftermarket rotor? I can't imagine Yamaha letting parts like that thru quality control...
The pickup is not adjustable, at least as far as I can see? No oblong hole, and no hole to rotate the stator either:
As a followup to that, I see this statement in the Service Manual that says "Ignition timing is not adjustable."
Gary, thank you so much for your help this far! Never would have gotten this far without you guys here. I'm just puzzled on how to proceed from this point.
any thoughts?
Michael
