Ok so im giving you guys very little to work with but i should be able to do more later in the week. I haven't done a compression test or anything but i will when i get the tool.
When im slowing down (downshifting and engine braking) it almost wants to die. It seems when it is just above idle (going up or down) and i get off the throttle, it stumbles for a second. it doesn't actually die and it never has but it may be just because i wont let it. i rev it back up until i get completely stopped. Could one cylinder be going away for a second? Im thinking jetting. i havent done anything to make it richer and it is finally getting cold. Its usually around 90s in the summer and it seemed to be running good. but now its been 60 or below (yes, i complain about that weather haha). Someone said i should rejet for ideal performance with 10 degrees of change. I just rechecked timing and synced my carbs. Today i tried to kick it and it wouldnt start even with the choke pulled all the way out. I had to turn the throttle about half way or more to get it to run. Im expecting too much out of this old bike arent i? Should i put it away for the winter (2 months? hahaha)...
