cmattina1
After swapping the 78 engine for a 75 engine, and installing the pamco, I managed to get the bike running, after adjusting the valves a bit.
However, there are some issues, what I do know is if they are related
At first it doesn't idle very well and I don't know if it would have to do with installing the pamco incorrectly... if it runs does that mean the wires are correct?
or could just be timing, it kind of "gallops"
Second, when I try to put it in gear it stalls out immediately and then i'd lose all power. To get power back i have to apply pressure to the safety relay, as if it's not making a connection. It seems like the same symptons as a fauly sidestand switch, but i don't know if 75's have one, so it could it something that serves a similar function, i.e. the safety relay?
In reading, it may be that something is staying open in the SR, so when I apply pressure to it, i am allowing it to make contact... it's just odd to me because it worked fine with the old motor... If i can allow the bike to get power by holing the SR should I assume the problem is the SR, or could it somethng else?
Sorry for all the Q's, but this is just a very off one to me...
I should add the the starter motor is on it's way out (whirls/spins, but starts the bike on the 3rd try) and sounds like this guy's:
Only while pressing the electric start though, when i kick start it there is no whirling I think the starter motor is indrectly attached to the SR, so could that be it?
