MikeCas
Hey guys. I'm having a problem with sealing my sump cover plate. I thought this would be simple! Does anyone know the torque specs for the six bolts? Should I use gasket sealer? Let me know and thanks!
Mike
Mike
Going to try paint stripper on my next difficult to remove gasket. How long does it take to soften the gasket? Thx for the tipThe bolts are only M6 so you don't want to go much tighter than 6 or 7 ft/lbs. Personally I use around 6 and the cover seals just fine. I use no gasket sealer, just oil, grease, or anti-seize on the gasket. This makes it come back off easy. The "secret" here is to get the sealing surfaces TOTALLY clean. You must get every last bit of old gasket off. I use paint stripper. This pretty much melts the old gasket away (and any gasket sealer that was used). If you don't get the sealing surfaces eat-off-it clean like this, it's gonna leak no matter how tight you make the bolts.
I grind gasket scrapers on the broken end of old hacksaw blades. Round the corners so it won't gouge. And um tape over the teeth for the handle!
great for the upside down under the crankcase contortion and in the recess for the side filter.
