JohnnyAction
Selling everything - '83 engine, carbs, tank, wheels
Yes, that's right I'm selling everything!
Parting out this complete bike. Most parts have 1km or less on them. It was out for one ride up the driveway. Time for a new project!
Will ship or local pickup can be arranged in Brampton, ON (home) or Mississauga, ON (office). EMT or Paypal preferred.
'83 Rebuilt 650cc Engine (447) - Reduced Price - $650 - local pickup only
Completely rebuilt by Junior St. Clair using brand new Mike’s XS standard size pistons, Mike’s XS big cylinder block, gaskets and seals. This motor is in outstanding condition. Left side cover included without gasket, it was removed to show how clean the motor is. Can include engine mounts, if required.
Mike’s XS Keihin PWK carbs - $250 - SOLD
Includes air filters, cable, throttle tube and all mounting hardware.
Stock exhaust pipes with headers and gaskets - $100 + shipping
XS-1 Gas Tank w latch lever, new petcocks & new Yamaha badges - Reduced Price - $150 shipped
This tank has been completely revitalized from the inside out. First, I sanded down through 2 layers of paint, then added a clear coat to keep a rustic look. Then I cleaned and resealed the tank using the POR15's motorcycle tank repair kit. The inside is MINT - see picture. You won't find a tank like this. Very authentic. No cracks or leaks, visible dent on the left side.
Special cafe racer seat - Reduced Price - $120 - SOLD
Mint seat ordered in from Vietnam with Mike's XS hinges included
Heavy duty 530 drive chain w rivet type joiner link - $60 shipped
Ignition Coil for TCi ignition - $20 - SOLD
Ignition w key - $40 shipped
Rear brake caliper sealed w reservoir – $40 - SOLD
Rebuilt with new seals and pads
Yamaha R1 front master cylinder w lever, NEW brake caliper & pads, braided cable & reservoir, Ninja 250 kill switch - $120 - SOLD
35mm forks, triple clamps with All Balls tapered bearings - $200 - SOLD
Completely rebuilt with all new seals & washers, Mike XS’s progressive rate springs and internal adjustable damper valve set (emulators). MUCH better handling than stock
Mike XS's 35mm clip-on handlebar set w clutch lever, grips & throttle tube - $70 - SOLD
Fork brace - $70 - SOLD
Helps stiffen the front end a lot!
'79 Special frame with a clear Ontario title w rear suspension & rear swing arm w pivot bolt - $200 - SOLD
I am the registered owner. Painted matte black. Back loop has been cut to fit cafe racer style seat. Swing arm includes bronze swing arm bushings & new seals.
19" front wheel w brand new Shinko tire, front disc, axle & new bearings - $200 + shipping
16" rear wheel w brand new Shinko tire, rear disc, axle, 32 tooth sprocket & new bearings - $200 + shipping
16" rear wheel w Dunlop tire (80% tread) w drum brake - $150 - SOLD
Rear drum brake set - $80 shipped
'01 Kawasaki ZX6e complete left rearset assembly - $50 - SOLD
'01 Yamaha R6 right rearset w master cylinder, caliper & braided line - $120 shipped
Stock piston block - $50 shipped
Perfect for an engine rebuild
Brake light w turn signals & plate holder - $70 shipped
Mike's XS Mirrors - $40 shipped
Headlight bucket & lamp w turning signals & brackets - $40 - SOLD
Mike's XS bar switch assembly - $40 - SOLD
Stock speedo & tach gauges w working indicator lights - $50 shipped
'82-84 Main wiring harness for TCi electronic ignition w fuse box - $40 - SOLD
