RoccoStreetTracker
The wife decided she wanted to learn to kick start our bike. The goal was, if she could kick start it, the bike would be hers.
I had just replaced the battery with this Lithium Batt
Bike would always start with one or two kicks. My wife is a small gal, so with all 105lbs of might, she could never get the bike to turn over. After about 10 min, battery is DEAD. Would barely power light.
One of the POs had "simplified" the wiring system. Kick start only, no blinkers, no horn, Headlight was fulltime bright, small LED running light in back and a brake light. Had a friend jump the bike with a jump box. I could kick it right up. 5 min of idling and I noticed running light flickers on and off. Unless I had the throttle open quite a bit, it would just die.
Looked at tail running light and found some bare wires, I covered them up.
Would this short cause the bike to die, or was the bike dying just because the battery was low. Before I put it back on a tender, it was about 10v (way below mfg low setting).
The last PO said the charging system was working when I bought it two months ago and so far the Shorai was a champ.
Any guesses?
I'll update you when I get the charged battery back in and started. Until then I'll read up on how to check the charging system.
Any guesses?
