Wanted - Side Covers XS1 XS1B
interacts
XS650 Collector
Australia
Wanted left and right side covers for XS1 or XS1B
Required for my XS1 that I'm restoring.
Need Carbs from XS1 or XS1B.
Chain Guard XS1 XS1B XS2 or TX650
Front Header Pipes Original XS1 XS1B XS2 or TX650
Seats XS1 XS1B XS2.
Gauges XS1 XS1B.
Fuel Tank XS1 XS1B or XS2
Let me know guys as I'm bringing this very low numbered XS1 Back to brand new condition. S650000497 build October 1969.
There WERE some changes with the early sidecovers.
I don't have all the details, so I'll just post what i have.
In this old Euro parts manual excerpt, the 70-72 sidecovers (#10 & #11) all have the same base '256' part numbers, with a -01 revision, apparently superceeding the unknown -00 original. The -?? suffixes are supposed to be just paint codes.
This Parts Bulletin shows changes to the early '70 sidecover bolt.
Perhaps member TXXS has more info?
Thanks for the info TooManyXS1Bs.
Ok it looks like all the side covers from XS1-XS2 are the same.
Never seen side cover bolt with a clip hole in it.
I have been told by guys that owned these bikes in there day that they have had a side cover come off or a side cover bolt work loose.
View attachment 62383 View attachment 62384 View attachment 62385
Hi 2M
The XS1 side covers did differ.
I recall that the hole diameter was different.
I will see if I can find one on the weekend.
View attachment early_XS1.pdfHere is a photo of the early XS1 side cover bolt etc.
The side cover has a smaller diameter hole to suit the smaller diameter bolt.
I only found this type of bolt on my low serial number XS1.
Later XS1 XS1B XS1F XS2 TX650 had a larger diameter hole in the side cover and a larger diameter neck on the bolt.
However the thread size is the same for all types of bolts.
View attachment 62502Here is a photo of the early XS1 side cover bolt etc.
What is the thickness of the unthreaded part of the bolt?
