Bob Kelly III
Ranch Kid from way back,.... that got Old !
Hi Paul ! Yes I'm afraid so the cylinders have to come off to get the piston pins out so the rods can go with the crank
though the can chain can be split you still have to take it apart anyway so the cam chain could stay in one piece and go with the crank.
you can work the cam chain off the cam itself with a bit of hocus pocus and contortionist moves ! and let it fall down to the crank....
but you still need to raise the cylinders up enough to get the piston pins out so you can get the rods disconnected....
so i think it's best all the way around to just disassemble the thing that way you can inspect the gasket surfaces and prevent oil leaks !
2M I read Dave's thread and noticed that gggGary posted his wobbly crank problem there too... seams to me that the XS650 has a serious weak spot ...the crank ! they slip !!!!!!! I am wondering now how often does this happen ? is it a common problem or am I just one of the lucky ones ?
..... Bob........
..... Bob........
