Orion61
OK I did fix it,as follows; I wrapped one spot with Black Electricians tape to see exactly what was needed, I found out 7 wraps of tape made the center rod tight to the point of where it expanded the total grommet, I wrapped the whole shaft very tightly and put 3 vertical strips of super glue on every wrap (each strip 1/3rd of the way around). After I was done wrapping it, I couldn't squeeze the grommets all the way in. I had to put one washer on it to pull it together until I could get all the large washers and lock washer on it. The end result is exceedingly firm. it can pull and push a little bit, 1/8th - 1/4" but it feels like it should, and I can't see a reason for replacing them now. I got a lot done on it today, I got the Bars done, replaced a broken turn signal, both hand levers and a new (Dealer take off) seat that has been sitting in the shop since 1976. I ended up paying $300.00 for the seat, but If I am going to refurbish the old girl I want to do it with as many old stock items I can.
I do have a dead right hand flasher and when I put the new flasher stalk in, I saw someone had soldered two red leads and cut them off so there was no exposed wire, I am going to open another thread for that. I took some pictures of the inside of the headlamp bowl from different angles to show as much of the wiring and different angles and pulled apart to see the wires better.
Thanks everybody, I believe this thread is resolved to my satisfaction.. I do have to add money is a huge issue right now. I got hurt at work very badly and ended up with 8 surgeries. The end result is I am for most part disabled. A Judge and my specialists (and Family DR of 24 years) agreed, BUT they have my Disability claim totally messed up, I get 2 or 3 letters on everything showing opposite points in the same day!!!! but mostly they are only giving me 1/3rd of what I am supposed to.
Even they admitted it, and I got ONE correct check, THEN next month they said they over paid me and KEPT the next two months checks COMPLETELY!!??
I have a Lawyer now, which means money but I just can't get anybody to take this issue and follow through, even tho I have all the paper work I need proving it. The issue is they seem to think I am getting checks from Work Comp, AARGH sorry for the long note of my business, but I have to do what I can with the bike on the cheap! I bought the seat 14 yrs ago.
The advice is much appreciated!
Larry
Larry
