The other weekend on the start line at high revs the clutch in the sidecar started to grab. I suspected that the basket tangs might be worn excessively from the hard starts.
Tonight after removing the cover it was a mixture of good and bad news. The clutch basket is not too bad and there are no broken springs but one clutch plate as flown apart and the nuts holding the cush assembly together have been rubbing on the case.
It could have been much worse. Now is a good opportunity to fix that starter spring while it’s apart as at this stage it’s looking like a strip down and clean out job.
