truenorthmetal
on my HD I used a 4 position starter switch ............ with the 4th position being momentary start...........and was able to do away with the starter relay and the starter button.
just installed a kill switch to stop power from going to coil.
Now on the xs....it seems that what a lot are referring to as a solenoid is actually a relay...
and therefore I should be able to do the same thing.....
Does anyone know if I can use a 4 pos starter switch not install the stock relay...?
This is the ig switch I have......
http://www.tcbroschoppers.com/weatherproof-ignition-switch-with-momentary-start.html
