MN_Bobber
79 XS650 Newb
[/IMG]All right guys, I need some assistance. I can't seem to get my steering coumn installed correctly. I changed from the ball bearings to the tapered bearings. The races are seated correctly and completely. The bottom bearing is seated all the way on the steering shaft. When I go to install the steering column into the neck and put the top bearing on, it won't go down all the way. I can't get it tightened up correctly. It seems as if the top bearing is beeing stopped by a collar machined 2 1/4 inches from the top of the shaft.
Here are some measurements I just took:
Chasis neck length - 6 3/4 inches
steering column shaft length - 9 inches
top of shaft to machined colar - 2 1/4
Anyone got any advice? This is starting to wear on me as it should be very simple. I'll try and get some pics up if that will help.
Sean
Sean
