Those bulb holders are quite common and easily scrounged from other bikes. Or, if you've eliminated your RLU, you could use that bulb holder, or the one from the brake light failure light. When I switched to an L.E.D. tail light bulb, my brake failure light came on. I guess the current draw was so low it fooled the sensor into thinking the bulb was bad. I removed the bulb from the indicator in the dash.
